Charlie69's 1985 Nissan 720 ST King Cab
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Charlie69
Car: 1966 Datsun 520
Left the Williams run about 1:30 pm after having lunch with Fun5ten (Ben) & rv510 (Rich) to go to Kingman to look at a 1985 Nissan 720 ST King Cab.
Well I was sold when I saw The ST Alloys!!! The problem is there is no title it was abandoned about 13 years ago on some property where it stayed until they owner of the property gave it to the current seller about 4 years ago. He could not get it running. lost interest and listed it on Craigslist for $400.
Long story short I purchased it for $200 as is with a bill of sale. It is now in Gene's back yard.
Got a little done on the 85 720 ST with Gene's help but got rained out. Had no power to the fuse box so started checking out the battery terminals are real dirty, so cleaned those. Still no power to the fuse block. took the fuse-able link apart from the battery terminal screw, cleaned the copper piece that the screw goes though and installed a new terminal bolt. now have power to the fuse box. Removed a hack installed Cal Custom cruise control. Every connection was made with scotch locks. The worst way to make a connection.
Sprayed some starting fluid in the carb and it fired and ran for a few seconds.
Found that the fuel pump was bad. I think I have a good used one, if not I will order a new Facet Fuel Pump. I will replace all the old rubber fuel lines and while I have them of the steel lines I will spray carb cleaner in them and let it set for a few minutes, then I will rubber band a couple paper towels over one end of the steel lines and the using a compressor I will blow through the lines. The paper towels will catch any thing that comes out of the lines.
Started pulling the gas tank and the rain started and got rained out.
Also Gene pointed out that the spare tire under the truck was also an ST wheel.
Pictures to come later.
Did not know Gene took these pictures with my camera.
waynosworld
I would not do to much to it till you get the title figured out Charlie, you might not be able to get one.
I can help you with the title issue. Piece of cake.
Charlie69
waynosworld wrote:I would not do to much to it till you get the title figured out Charlie, you might not be able to get one.
Hi Wayno,
Just enough to make sure it is worth titling.
Charlie69
AZhitman wrote:I can help you with the title issue. Piece of cake.
I am all ears!
Let's chat this weekend.
Charlie69
Works for me.
Charlie69
No all nighter, a few hours here and a few hours there, about 5 hours and it runs. Need to work on exhaust noises so I can better here the engine run. the hydraulics are bad, both brake and clutch. I have all new brake parts except the hydraulic hoses. Need the clutch hydraulics though. Needs u-joints and carrier bearing, I have a new carrier bearing. cooling system as of now works.
The tank looks real rusty so I will take it to Tom my radiator guy and have him flush it. He does not charge me if he can not get it clean. Like all of the stock carbs it runs ruff and rich.
Not going to put much money in to it until I know more about the engine. The trans shifts through all 5 gears and reverse works. Rear end works.
Gene has some video of it running. I hope he will post it for you guys.
Charlie69
ST gets some bling. I traded a 38 Weber for the tires and wheels plus was paid $50 cash on top of the wheels.
The ST wheels will get polished and new tires. These will be on my 1986 720 King Cab until I decide if this one is worth titling.
Return to “Datsun 720”
