PROBLEM: Alternator doesn't charge until around 2000rpm when the car is first started but after the car hits the 2000rpm mark the voltage goes up and alternator charges fine until the ignition is turned off. Also it seems like there isn't enough power when car is just idling after car has hit the 2000rpm mark. The battery and alternator have both been tested are are "good."
CAR: 1993 300zx TT running stock ecu with no electrical mods / alterations to OEM wiring
WHAT I'VE DONE: 1) new / rebuilt TT alternator - no change
2) new optima red battery - no change
3) new battery cables - no change
Is there another voltage regulator other than the one built into the alternator? If so where is it?
Thank you for your help!!!
