NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Oct 14, 2003 11:28 pm
the entire electrical system is actually part of the charging system. Reason I say that is if even one compent is drawing more then 50 milliamps when the car is not running it can drain the battery. but your charging side would be batt cables , alt fuse/link but the main wire for charging the battery is the big one on the alternator. It goes directly to the battery. the other circuit is for the voltage regulator inside the alternator.
