Charging Air conditioning
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Tilade
Car: 07 Nissan Versa--very stock at this point.
Hey all. I'm thinking my versa needs more coolent or a recharge. I can't find insturctions specific for how to do this with the versa. Can someone explain where I need to connect the R134a can to and what to do then?
Thanks!
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
Take it to a shop and let them do it. it's not worth the hassle.
Tilade
darn, ok i'll have to consider it. One quick question though--is it easy to add oil to my compressor if I know how much is needed?
SVTfocusO3
Car: 2009 versa
NO, it is not easy, you need a tool.
There are some TSB's on the a/c for this car probably.
I am sure if you go to one of the auto parts stores and buy one of those devices that hook to the a/c and charge it, they will help you out and show the proper way to use it to recharge it.
All this is done on the low side.
Oh, this may not be your problem, at all.
Return to “Versa Technical Discussions”
