daniel240 »
https://forums.nicoclub.com/daniel240-u4418.html
Sat Dec 06, 2003 2:35 pm
it sounds like you are doing the exact same setup as me. i just got my smic mounted tonight. i got mandrel bent pipes from a diesil truck place. i ran 2.5'' from the turbo to the IC. and i ran 3'' from IC to the TB, because i used part of my hs intake that was already 3''. it really doesnt matter that much what size piping you use, especially at low boost. as far as the hacked mafs, if you are doing the pull through method, then you wouldnt have to worry about the IC piping size. btw, the 2'' stuff at the hardaware store is kind of small and the bend is not very tight. i was going to use that stuff as well but decided to use all 2.5'' and 3''. if your smic is like mine the connectors on it are almost 2.5 so 2.5 piping is perfect, at least for the hotpipe. to shorten piping and for less work i mounted my smic on the drivers side where the lower original air box used to be, in front of the fender. there is a lot of room in there and there is a big opening in front to keep it cool. this way you dont have to relocate your battery and your piping is much simpler and shorter, creating less lag. it was very simple for me, i used 2 90's and a 45. i had to cut out a little of the metal to get down there to run the pipes to.ps, what size ID pipe are you using for you hacked mafs? im assuming your using the 370 injectors.
