Charcoal Cannister....
Rosco
Car: 91' SR'ed Hatch
Is the Charcoal Cannister needed? How should I remove it and or plug it? Also what is that line for that goes from the throttle body to the coldpipe?
Blown240sx
Car: 1996 240sx
The pipe from the throttle body to the cold pipe is for IAC I believe or some sensor. Its needed.
The Charcoal Cannister? Are you talking about the can ont he back of the sr block nearest the Turbo?If so that is the Stock Oil Catch can or the Oil Blow by Can. It catches oil that is pushed out of the valve cover. This is so crank pressure doesnt build up. You need that but you can go to an aftermarket one.
Rosco
No The thing I'm talking about is mounted right around the air filter. It has a hard line from the fuel tank going to it. It's stock piece that is not attached to the block.
Blown240sx
Car: 1996 240sx
thats probably one of those emissions canisters. Id say see if you can get rid of it cause only thing you need for the fuel int he engine bay is line running through the filter and a return from the fuel rail.
Rosco
Thats what I was thinking, kewl...thanks.
Nismo_Freak
Car: 89 Nissan 240SX
It's the evaporative emissions canister (aka charcoal canister). It stores excess fuel vapor from the gas tank and the valve on top of it causes it to release the vapor during cruising into the engine.
Just remove it and plug the vacuum lines from the motor. The other lines need to be ran open and away from spark / exhaust.
forksquared
Car: 91 Nissan 240SX coupe
98 Subaru Forester S (New DD)
does anyone have a pic of the stock oil catch canister?
Blown240sx
Car: 1996 240sx
its located on the back right of the motor if your looking at it from the front of the motor. It has a tube running from the valve cover to it. then the other side of the T goes to the intake hose.
forksquared
im pretty sure i dont have one
Pepperoni
Where does the bottom part of the charcoal canister plug into? I'm currently putting in the emissions stuff for smog (S13 blacktop) but i'm not quite which lines should be connected to the charcoal canister, especially the line on the bottom. FSM doesn't really help too much but i'm going through it.
Are the charcoal canisters for SRs and KAs different? Didnt find one in my clip to verify.
boost_creep
Car: 92 sr powered coupe,06 Spec V
the bottom one goes to the metal hardline that runs along the top of the driverside framerail.right below the mafs.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
oil catch is the vertical black box that is "next" to the brake booster in this picture..my strut bar kinda blocks the view but whatever
forksquared
you dont need it right?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
you can put breather filters on instead i guess
spider_slayer
Car: S14 240SX
S13 240SX
i'd keep it on.......you CAN put a breather on, but the pressure will build up in the crankcase and you will waer out your piston rings premautrely.
Rosco
Aftermarket or "home-depot" oil catch will solve that...
drifter_for_life06
Car: Daily: '16 WRX
Exocet
phase2 sells circuit sports small and large ones..if you want ot be "inconspicous" sp? about it, get the small one..its pretty cheap
Nismo_Freak
Pepperoni wrote:Where does the bottom part of the charcoal canister plug into? I'm currently putting in the emissions stuff for smog (S13 blacktop) but i'm not quite which lines should be connected to the charcoal canister, especially the line on the bottom. FSM doesn't really help too much but i'm going through it.
http://www.camel-towing.com ... look at the FSM.
boost_creep
why is everyone talkin about the catch can, when the name of this thread is charcoal canister?two different things..
Blown240sx
Car: 1996 240sx
Why did you post something so stupid ^^^
If youd take the time to read, we answered the first queston and moved on to another.
Thank you for a worthless post.
Nismo_Freak
Blown240sx wrote:Why did you post something so stupid ^^^
You're one to talk...
boost_creep
lmao...
why is everyone so quick to be an a**hole on this forum.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Pepperoni
89 240hatch wrote:the bottom one goes to the metal hardline that runs along the top of the driverside framerail.right below the mafs.
Wouldn't that be the hardline that goes to the gas tank? Or is there another hardline down there? I'm referring to a hose that is connected to the bottom of the charcoal canister. I can't remember where it went before I swapped.
Top of charcoal canister has 3 nipples and one on the bottom of the canister. But for some reason other charcoal canisters i've seen dont have the bottom hose...
Neil
Car: shooting laser guns
spider_slayer wrote:i'd keep it on.......you CAN put a breather on, but the pressure will build up in the crankcase and you will waer out your piston rings premautrely.
... What??
I have heater hose coming off the crank fitting, routing up to the valve cover T fitting, and a breather filter on the other side of that T. The only bad thing that happens is the oil vapors over a few months foul up the cotton filter element of the breather filter, but the cost per filter as opposed to loss of heat transfer efficiency due to oil buildup inside my intercooler is worth it.
If you capped off the crank/vc ventilation system THEN you'd cause harmful pressure to build up... these filters allow you to not have to rout the gasses back to the intake and prevent mess at the same time, hence the term "breather"
drifter_for_life06
Car: Daily: '16 WRX
Exocet
Rosco
Thanks for clearing that up.
Blown240sx
Car: 1996 240sx
Nismo_Freak wrote:You're one to talk...
Yes I am.
Have a nice day
Pepperoni
Thanks for the reply. I have looked over both KA and SR FSMs numerous times but they don't clearly state where each line goes, unless I overlooked them, but i'm pretty sure I did not. Plus, neither even mention the bottom fitting...which is what is confusing me so much.
