Chezedik wrote:The only other thing I can think of is that it is causing vapor lock from increased tank pressure, you may think about a vented cap. Besides, if you haven't replaced it in a while, then it will help mileage. Also, the reason your idle gets better when the AC is on, is because the IACV is opened a little more by the computer when the AC is activated.
EDIT: Not really vapor lock, but some kind of other pressure related condition. Like maybe there isn't enough of a differential.
How will a vented cap help milage? I understand that it may cause the missing, but how will can it screw mileage? Noob question for sure.
sleepyRPS13 wrote:just wondering if the bad idle also happen when warming up your car?edit: i would also check the IAC, maybe clean it up or something. GL
Idle is perfect when cold, only goes to missing when car is completely warm. Another noob question, but wtf is a IAC? I have removed some of the emissions stuff, like the black box between intake and exhaust manifold, and the cat. I am interested in blocking off the EGR if it will benefit in any way when I install the new header.
s13satch wrote:So why did you remove the charcoal canister? There is nothing mechanically good that could come from removing that piece.
Because it was ugly and in the way. I needed more room for my super rice filter when I get the new intake tube. I like a little show just for me, although no one ever gets to look under my hood. All these riceboys think that all 240's came with SR20, so wtf?! I just let them keep thinking, especially when I smoke their POS non-VTEC single cam h0m0 dx. Going from 2nd to 5th in town is a blessing. They really look funny when I go from a 5 mph in 2nd all the way to 55. They think my first gear is hella-long.
