Charcoal Canister removal
KrAzy24DE
Car: I need money
I tried a search for it and didnt find what i need?I am almost done with my Ka-t and need to make space in the engine compartment.. I wanted to Know if there is anyway to remove the Charcoal Canister And If I remove will there be any idle or performance problems when its removed?Can someone help me out on this?thanks`jp
Structure240sx
no problems at all. just cap off where the vaccuum lines end. this is what i did
onosqv
Car: '92 240sx Vert
Structure240sx wrote:no problems at all. just cap off where the vaccuum lines end. this is what i did
Actually, I believe it may lower your mpg just a little from the threads I read. Something w/ the carbon canister recycling the fuel vapors -> remove canister -> venting vapor to air -> lower mpg.
But back to the subject, yes, just block off the 2 or 3 vacuum lines w/ vacuum caps & maybe a couple clamps for safety. Then vent the metal line that is connected to the bottom of the can - you may want to put a "breather filter" like I am doing on it so that nothing accidently falls into that tube.
KrAzy24DE
Car: I need money
thank You for the quick replysIts very much appreciated`jp
get_up_mark
Car: 98 240sx se
is that canister also referred to as the purge canister. i was thinking of doing the exact same thing minus the breather
Import_Ant
I removed mine with no issues... It's only been a day but it seems to run fine minus the low idle I need to adjust)
mccune240
will this work for SR's too?
lord_hypnos
Charcoal canister is different than the AIV?
mccune240
i need to know if an s14 sr needs a charcoal canister to run correctlydoes anyone know
Modified by mccune240 at 7:31 PM 8/24/2006
Raxephon
Car: '04 RX8...for the moment...
mccune240 wrote:i need to know if an s14 sr needs a charcoal canister to run correctlydoes anyone know
No, a charcoal canister is not necessary but you will lose some mpg.
You will have pressure build up in the tank though.(Every time you open the gas cap you'll hear a "woosh" and smell gas vapor)
KATwo40
Car: 1993 240sx KA-T
If the tube is open to the atmosphere with a filter on it, how can pressure build up in the tank?
However, I wouldn't want fuel vapors randomly building up in my engine compartment, near the exhaust side, regardless of open flame probability.
Raxephon
KATwo40 wrote:If the tube is open to the atmosphere with a filter on it, how can pressure build up in the tank?
Normally you would simply plug/cap off the lines to avoid the possibility of fuel vapors building up in the engine compartment and being greeted by some form of ignition.
Since the lines are capped, the fuel vapor will build up some pressure in the tank.
