Changing your own oil on QX60 ??
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
jdsaengine
Car: 2019 Audi A7
2017 Corvette Vert
2014 QX60
Getting ready for first oil change, got 3500 mi on it. I'm a car guy with hot rods and Corvettes and usually change my own oil.
Looking at a factory service manual on-line, it looks like you almost have to take the right front wheel off and the plastic inner fender out just to get to the filter? :confused:
If thats the case I may forego bothering with that operation. At the same time I can't see a drive in lub place doing the job either with that kind of effort needed. So. . . is taking it to a dealer the only real option for an oil change (and their $60 fee). Or is the do it yourself job a little easier than it looks
And I do the oil changes on my M35X with the twelve or so bolts removing the plastic under pan ( which is a PITA) so its not like I won't do a little work to get to the oil filter
avknav
Car: JX35
i've changed the oil and filter on my jx. i was able to pull the inner splash shield out of the way and reach the filter no problem. it is held on with a few push pins but near front there are none so it can be moved about six inches providing enough room to r&r filter
jdsaengine
Car: 2019 Audi A7
2017 Corvette Vert
2014 QX60
Thanks for the feedback
haipham100
Car: 2015 QX60, 2996 E=Benz E350
Have anyone able to get to and remove the oil filter of the QX60 ??? It's rather in a hrad place to get to ...
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
haipham100 wrote:Have anyone able to get to and remove the oil filter of the QX60 ??? It's rather in a hrad place to get to ...
Welcome to NICO! I've merged your thread with an existing one.
This link may further assist you: Engine Oil and Oil Filter Replacement Procedure
Return to “Infiniti JX35 / QX60 Forum”
