manchini »
https://forums.nicoclub.com/manchini-u40536.html
Wed May 17, 2006 3:04 pm
1. Go to you local party store and purchase some cellophane paper. The color u are looking for is magenta or red. Now all u need is a very small quantity so buy at little as u can. Luckily it was on sale and I was able to purchase a whole role for $1.
2. Remove the clock from ur car and bring it in the house where u can easily work on it.
3. Remove the cover of the clock and remove the circuitry from the housing. Take a small piece of cellophane paper (all u need is one piece, no need to use double layers or u will get a reddish color and a blurry read out).
4. Take the small piece and attach it to the lcd using clear tape. I say tape it to the lcd and not the cover because its a little tougher to get cellophane paper to stay flush against the cover which in turn would lead to a blurry read out. Make sure the cellophane paper is tightly pressed against the lcd and space between the lcd and the cellophane paper is at a minimum.
5. Reassemble everything and ur done.
got this off a link a while back worked great for me
