180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Dec 26, 2006 9:39 am
you don't. rotate the hub to that section where the caliper was. Thread on a lug nut till the face of the lugnut is pretty flush with the stud, and give it a good square whack on the head of that and you'll get one popped out lug nut real quick. Repeat till you get em out. To put them in, pop the stud in from the back of the hub, put a couple washers there and use the lug nut to pull the wheel stud into place.
