Changing VK45DE M45 Spark Plugs..Found a Link
jallow33
Car: 2006 Infiniti M45 Sport
Graphite Metallic
Technology and Journey Package
XM/NAV/DVD
I saw the sticky for the VQ35DE M35 instructions on how to change the plugs, but I also found a link for the M45 Owners as well in case its needed. Not sure if it applies for the 03-04 years
I tackled the job this weekend and I referenced this, took about 45 mins
http://www.mq70.com/forum/threads/370-M ... -Plug-Swap
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Typically with these engines, it's important to use NGK plugs with no substitutions on these engines!
Thanks for the link.
jallow33
Graphite Metallic
XM/NAV/DVD
Indeed, I went with G power Platinum NGK, $50 shipped from Ebay
Was told V Power, G Power, or Iridium should be fine
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
I used that same link to guide me.
I used the NGK Laser Platinum plugs (PLFR5A-11).
You will definitely need several extension lengths and universal joint sockets, because plugs #8 and 7 are a b*tch to get at.
The tip to use a short 1-2 foot rubber hose as an extension to hold the plug as you're screwing them in is money!!!!
I thought I had majorly fracked up when I was torquing down the coilpack bolt and the head broke off,, guess i don't know my own strength-LOL....had to get a bolt extractor, man that took a while....able to find a replacement bolt and eventually good to go!
