Changing Versa Brake pads, any special tools needed?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Legacy40k
Car: Versa
I've decided with the help of a friend to change the brake pads on my versa myself this time around to save a bunch of money. It seems like it's pretty simple to change brake pads for a disc brake (I assume drums are harder but don't have to be done as often?)
My friend suggested I check if there are any special tools required.
So.. Is it easy to change the Versa's brake pads? Does it matter that is has ABS? and are any special tools required?
biggie
For disc brakes you will need a tool to press the piston of the caliper back some before putting in the new pads. Otherwise just sockets/wrenches to get the caliper off/back on.
ABS/non-ABS doesn't make a difference when just chaning pads.
Example of Piston rotation tool:
Return to “Versa Technical Discussions”
