tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Tue Mar 23, 2010 6:55 pm
You have to change out a lot of stuff.
Shifter assembly, trans, TCU, ECU, wiring harness, gauges....
you can do it for around $2500 if you source the parts correctly and do the work yourself. Maybe a little less. If you have someone do it for you...way too much.
