changing transmission fluid / oil on s13.
sanioll
Car: Nissan 240SX SE
Toyota Camry
Ok, i'm very new to this, my first time. it is for people who WANTS TO KNOW.
i changed oil on manual transmission of 92 240sx se.
HERE ARE THE STEPS:
stuff you need:
1. gear oil----75w-90, GL-4. i went with Redline mt-90, GL-4. MAKE SURE IT IS GL-4. other ones, like GL-5 will eat away your syncrhos.
2. good wrench, i mean really good one. i broke 2 of them trying to get filler plug out.
3. 1/2 inch ratchet-- to take out drain plug
4. rubber gloves--if you want clean hands. and YOU DO! oil=skin cancer
see the pic..
fiznat
Car: Grown up :(
oil = skin cancer?
Thanks for the writeup though...
AkademikONE
Care to finish the rest of it? You stopped at what we need to do it. =)
sixxdeuce
Car: 93 rx7, G35coupe 6mt
1. pull the drain plug2. let all the oil drain out3. put the drain plug back4. pull the fill plug or shifter5. fill the trans by adding oil to the filler hole(side of trans) with a suction pump, or remove the shifter assembly and pour in through the top if you dont have the pump5. put the filler plug back in or re-install the shifter when trans is full.
AkademikONE
I knew how to, I just wanted to point out he could have finished his write-up. =)
