^^ Yep My drain bolt had a crush washer on it, it was a bit bigger than the one for the oil drain. I've drained it twice with the same washer next time i'll change it thobigdaddychia wrote:only thing u need is a long thin funnel to get the fluid in . Other than that its a simple removal of the bolt drain and fill.
Following the premium maintenance schedule, you should change the CVT fluid every 60,000 miles. And I heard it can only be done by the dealer since the fluid is not the same as ATF and is proprietary.DanWit wrote:I believe he's changing an automatic transmission's fluid not CVT. However, how often does a CVT's fluid need to be changed?
