+1 same rule applies to the diff. Always make sure you can remove the fill plug before draining.Z-owned wrote:On the side of the trans if I remember it's on the passenger side haven't changed the fluid on mine in awhile. For future knowledge it's always a good idea to make sure you can remove the fill plug before draining the fluid.
