evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 07, 2007 6:56 pm
it's really not too bad, the seals can be tricky mostly due to the crank gear not wanting to come off and not being made for use with a puller, some people recomend splitting it and replacing it? I simply left that seal alone as it wasn't leaking, as for the rest of the stuff, once you remove the intake piping, rad fan shroud, and get the fan and clutch out of the way it's all pretty easy, just pull the accy belts and the timing belt covers and it's all pretty much right there, honestly I found it easier to do the timing belt on the Z32TT than my old Z31 N/A, be sure to have a FSM handy, be sure you get everything lined up correctly and sped a couple dollars more the replace the tensioner stud while you're at it, cheap insurance
