kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Fri May 12, 2006 7:05 am
Well, I dropped off the head at the machine shop yesterday. I think I'm getting ripped off on the price but this guy is the only one in my area that's reputable among the speed shops. He's charging me $250 to disassemble the head, check the valves and lifters, replace the valve stem seals (which I provided for him from my gasket kit), reassemble the head, and deck the surface. I've decided to ditch the metal HG and swap it for the OEM one I have on hand. The block is still in the car so milling the block to ensure a perfect mating surface with the head is not going to happen.
On a related note, I'm scrambling to try and find either some OEM replacement head bolts or an ARP head stud kit by tomorrow afternoon because I have to get everything back together by Sunday night. In my ignorance, I thought that I'd be able to reuse the old head studs but after a bit of research and a tongue lashing from my buddies about the sheer stupidity of doing that, I've decided to get some fresh hardware in there. Anyone know if there are any OEM head bolts that crossreference to a USDM nissan motor?
Also, since I'm swapping in the OEM headgasket, should I still use the copper gasket spray?
