float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed May 05, 2004 1:59 pm
Alright, so I'm going to order the parts to fix the rings. My question is, would you guys recommend doing it from the bottom end (holding the motor up, dropping the subframe. Remove the oil pan, rod and main bearing caps and drop the crank,rods,and pistons all at once) or doing it from the top ( pulling the oil pan, removing the rod bearing caps, pulling the head, and popping the piston's out. ) I think it would be easier to do it from the bottom, but it seems that everyone does it from the top. Just wanting to know everyone's opinion. Thanks!
