changing relays
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
dutchey
Car: 2004 armada le
i have found the relay that controls my day light running lights. how do you change it. is there a clip or catch that holds it in. any help?2004 armadathanksdutchey.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
dutchey wrote:i have found the relay that controls my day light running lights. how do you change it. is there a clip or catch that holds it in. any help?2004 armadathanksdutchey.
Not sure on that one, did you check the service manual? Here is a link to the service manual:
http://www.nicoclub.com/FSM/armada/
dutchey
Car: 2004 armada le
I talked to a nissan dealer, he said it should pull right out,not. I found that on the back side of the relays is a clip, push a small screw driver in between the clip and relay and wiggle relay at same time.dutchey
Return to “Armada Forum / QX56 Forum / QX80 Forum”
