Changing power steering pulley ratio? Anyone?
Desmoquattro
Car: 1991 Infiniti Q45
1997 Ducati 916
I'm wondering if it would be possible to change the power steering pulley ratios to firm up the steering on my 91 Q... Anyone tried it or heard of it on a Q? If so does it give worthwhile results?
Just something I'm thinking about to put into the list of "possible future projects".
Q45tech
Reset rack pinion preload to as firm as you desire.
RAP
Car: 2000 Infiniti Q45
Nissan 240SX's
'95 Acura Legend
'91 GMC P/U
Plus other junkers around the yard
Desmoquattro wrote:I'm wondering if it would be possible to change the power steering pulley ratios to firm up the steering on my 91 Q... Anyone tried it or heard of it on a Q? If so does it give worthwhile results?
Well you try it and let us know. That would make for a new thread as there seems to be a lack of interesting subjects to discuss lately. Well at least for us newer Q45 owners.
What I do know about the power steering pumps, at least on my 2000 is that it seems identical to what is used in the 240SX. I have not actually had the Q45 pump in my hands but have had the 240SX and the Sentra also. However looking in the Q45 FSM they all appear identical.
The pumps are variable vane type. They would be an ideal pump to use for non-critical, hydraulic projects apart from cars. Maybe install power steering on your moto-guzzi...
Jack
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Q45tech wrote:The steering rack pinion preload is infinitely adjustable over the less than 90 degrees safe range. Set you steering stiffness where you want it..........just be careful of excess where the rack might bind in cold weather!
Follow proceedure in FSM...................tiny tiny increments say 5-10 degrees at a time.
It will change depending on PS fluid and rack temperature. It will change as PS fluid ages.
Desmoquattro
1997 Ducati 916
Excellent, I'll keep the preloading trick in mind. Definitely less trouble than replacing pulleys / pumps.
RAP
Nissan 240SX's
'95 Acura Legend
'91 GMC P/U
Desmoquattro wrote:Excellent, I'll keep the preloading trick in mind. Definitely less trouble than replacing pulleys / pumps.
BTW, Desmoquattro, all that adjusting stuff is mentioned in the FSM.
Jack
Desmoquattro
1997 Ducati 916
I've got to read through that thing a bit more, I've only given it a cursory glance.
