paranoidjack wrote:
Hmmm. Not a big fan of that method. But if that's what it is, so be it. I'd prefer a proper drain and fill.
If you have noticed there is not much help on your issue? I too have studied the FSM and the ABS system and argued my case here about weather there is fluid trapped within the actual ABS control unit. The FSM does not offer much help and simply said to bleed the brakes in the usual manner, for both, brake caliper and ABS unit replacement or for any time there is a need to bleed the brakes.
The FSM displays a rather vague diagram of the function of the ABS and fluid flow. The unit contains some a pressure pump and a series of electro mechanical valves that are activated upon a signal from any one of three points, each front wheel, ,and from both back wheels as they are two for one.
The electro mechanical valves are contained within that ABS unit that you see in the engine compartment. If a signal is received from any of the non turning wheels the valves are activated, fluid pressure is relieved from that wheel and fluid is absorbed by the pump to maintain pressure for re-activation when the offending wheel is once again turning normally or at the same rate as the others.
That's my take on the ABS system installed in our cars but as stated prior, there is not much help from the FSM as the recommended procedure for a ABS malfunction is to R & R the unit intact. After re-installation of the ABS unit just bleed the brakes in the usual manner. Meaning, two persons needed, fill the master cylinder, pump the brakes and open the bleeder valve at the wheels, or, use a brake bleeder device.
The Consult is used to activate the ABS unit to check if it is functioning properly.
Hopes this helps and not added confusion. In any event the brakes are designed to function normally with or without a functioning ABS. Furthermore if you are an alert and aware driver you should not drive into any slippery conditions that will cause some device to activate and interfere with the brakes. No argument against test track results as they are under controlled and deliberate conditions.
Maybe more than you wanted but in any event, good luck.
Jack
