My name is Richard Precht, I live in SE Kentucky I am 70 years young. I've been a forum member about 1-1/2 years? I am here to ask if anyone here has done this and also installed a backup camera at the same time!
I love my 2010 Nissan Altima 2.5S (with 100K miles). I have just done a long research on which Double DIN aftermarket Audio Reciever with Navigation I wanted to purchase. I went with the Jensen VX7528 with the iGO primo navigation software and the seller is Crutchfield. The unit will be delivered in a day or two.
I will not be upgrading the speaker system or adding any amps or other 'gizmos'. But I am going to install a rear view backup camera on the trunk lid trim piece. (I found a YouTube video of that install on a similar year Altima - very good video). The backup camera looks to be very similar to the one I am planning on buying (here is the link: https://www.amazon.com/gp/product/B07DC ... _qh_dp_hza
As for the install of the Jensen Double DIN, I've been able to find some pretty good videos of Double Din installs, and Crutchfield sent me an installation PDF (which is pretty good). The Jensen purchase also included an Aftermarket Instrument Panel Cluster Lid (Cyber Monday free item), a Metra antenna harness, and Metra wiring harness (also free w/unit). I also purchased the Crutchfield's "ReadyHarness Service" (where they make up the harness to the OEM connectors so it is a true Plug and Play).
I may not be happy with the *AfterMarket Cluster Lid, so I found that I can buy a genuine Nissan* cluster cover here: https://www.autopartscheaper.com/produc ... -dash-trim
*(I will probably be getting the OEM lid as the aftermarket is the Scosche NN1642B and not textured?)
OK now for some questions if I may?
1) Which way did you route the wiring for the camera once you got inside the trunk?
2) Did you use the Driver's side, passenger's side, or down the center of the floor to the console?
3) The YT video said that the reverse lamp wire on the driver's side was used and "tapped into" using 3M T-Taps (crimped connects).
4) Which wire color is the reverse wire (the video said "purple?).
5) How difficult was it to get the camera wiring to the rear of the Radio? Which route worked best? Please elaborate on what was the worst part of getting the wiring routed for the camera.
THANKS for now.. I hope someone can share your experience with me. I think your experience will benefit me greatly in getting this project done! With nearly 60 years of doing all types of projects, this one will not be a big challenge - but it never hurts to ask for help from someone who has done it before! :wink
Best regards, Richard
