ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Aug 23, 2010 1:46 pm
pathfinder995
you will need ratchet, extentions and air operated impact wrench and spring compressor.
Loosen the 3 tower bolts on the fender both sides, do not touch the center nut
Jack up front of car
Use axle stands at the frame
Remove front wheels
Leave tie rods and lower ball joints alone
Clean off nuts and bolts at lower section of tower (2) use penetrating oil
Clean off strut stabilizer 1/2 way up tower, use penetrating oil, you may destroy this joint so buy a spare for each side, remove joint at sway bar at the very least.
Put hydraulic jack at lower ball joint
With all 3 bolts removed at top of tower, all 2 bolts at botton removed, and stabilizer removed, lower jack at ball joint, strut with non compressed spring will come out
Turn wheel to lock position and remove strut.
Put strut in a vice horizontally with spring fully out.
Mark strut spring position and bearing top position and mark 1 of the very top bolts to the fender so you know where that bolt lines up and all 3 will line up when placing back on car.
Do not touch center nut until spring is compressed.
With everything marked now install spring compressor opposite each other and hand turn to tighten down spring until the top mounting plate and bearing are at least down to the rod threaded area and the plate and mounting plate are able to be moved by hand.
Remove center nut, careful the bearing and mounting plate will move easy. If you use air tools enough torque is generated to remove nut without holding the center rod.
Disassemble the top mount and bearing, remove spring from lower mount, be sure marks are on spring and both mounts upper and lower.
Clean spring, remount to new strut, that is marked as old strut
Install new bound cover
Install existing or new mount top and bearing.
Align everything and tighten center bolt to nut, make sure all is aligned
Remove compressors
Remove strut from vice
Place new strut into bracket and align and install the lower bolts and nuts, snug them up
Align top mount to holes in fender.
Use an hydraulic jack at lower ball joints to raise assembly and line up the bolts to the holes.
If further twisting of the mount is needed use a socket , extension and ratchet at the fender turn the ratchet in the direction you need to get the 3 bolts to match the holes.
Jack up the hydraulic jack to lift the wheel assembly and the stru attached.
When all 3 bolts are through the fender place nuts on, raise jack the snug bolts.
Snug the 2 lower bolts
Attach the stabilizer link, keep the rod assembly flush
All things snug and placed right, send them all home.
Do both sides
Drop car
With car on floor tighten all to spec
Test drive
