Changing Out Radio and Wiring
Post all your Nissan electronics, car audio and stereo questions here!
michael228
Car: 1993 Nissan 240 SX SE Convertible
Hope someone can help! I am changing out my stereo and speakers. The person who had this car before me must have had some High Dollar Stereo in it because there are all kinds of dead ends and harnesses that are in the radio area but go now where on this current radio.
I have a new harness for the new Stereo System and that is easy enough to figure out which wires go where specially for the new speakers by the given instructions and color coding. The issue I have is the power wires.....looking at the Original Nissan Harness Plugs that are still there but I will not be using and the new Harness and the instructions to attach the red and yellow power supply leads from the new harness to................?? I am looking at the existing harness that is still in the car and trying to figure out........What color wires do I cut and attach to the new harness red and yellow wires power leads?? Anyone know? Thanks! Mike
huda424
Car: silvia s14
the yellow wire goes to constant 12 v and the red go to switched 12v. always double check before splicing.
1993 Nissan 240 SX Stereo Wiring
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Red/Blue Dimmer Red/Yellow Antenna Left Rear Front Speakers 4" x 6" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Kristoefur
Car: 2k3 Nissan Maxima GLE
Your best bet is starting here-----> http://www.crutchfield.com/App...=2977
Crutchfield has all the necessary parts and advice for wiring up your SX.
Hope that helps.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Yeah you can either hardwire it using the colors that were posted above or go to Circuit City or Best Buy to get an adapter harness so that all you have to do is match colors.
