ceningolmo »
https://forums.nicoclub.com/ceningolmo-u33477.html
Sat Oct 29, 2005 11:51 am
I tried to do the usual research before posting this topic... but, I couldn't find what I was looking for. So, forgive me if this has been covered elsewhere.
While Wes was going over my car recently, he found a bad injector. I believe #3 is the only one that showed a bad OHM rating.
So, I am thinking about starting the project of replacing it. Has anyone done a step-by-step walk through of this job? Any pictures? I am truly a beginner, so the more help I can get the better. If this is a job I should not try to tackle on my own... just let me know.
Also, was looking at parts on everythinginfiniti.com. They show several different colors for injectors on the 90-94/6 Q45's. Which is the right one? Do I need to match it against what is currently in the vehicle? Do I need to remove the bad one in order to determine the color?
Also, I am assuming that testing OHM loads is how to check whether the injectors have gone kaput electronically. But, an injector may become physically clogged or even fail physically without showing a bad OHM rating correct? So, how do I test my other injectors? Will I need to remove them all?
Thanks for the help.
