changing original fog lamps on a m45
amarp
Car: 2006 infiniti m 45
hi one of my fog lamps is broken on my 2006 m45. any idea or specs to changing it as i bought a new one and would diy. thanks
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Easiest way is to remove front lower grille surrounding the fog lamp:
You'll need to stick a screwdriver in the hole just to the side of the fog lamp opening (step #2 in above instructions), you can see the hole in the pics - I removed mine to paint them since they were getting a little ratty and chewed up.
Then remove fog lamp:
I believe you can use the Sentra fog lamps (forget the years) as a direct and cheaper replacement.
good luck with the install, I'm thinking about switching mine with the new VLEDs LED fog light bulbs once the weather warms up and I come into some cash.
Craig
amarp
thanks craig so if i read this correct then i have to remove the bumper to change the fog lamp
pedsemdoc
R2C Intakes
Oil catch cans
amarp wrote:thanks craig so if i read this correct then i have to remove the bumper to change the fog lamp
No, not whole bumper, ONLY the black plastic lower grille piece (photo). I couldn't get a shop towel around the edge, so I weaved some thin, but strong rope through some of the holes to give me some leverage to get one side off, then it was easier to rock/move the other side out.
hope that makes sense...
