Changing oil on 2007 Altima 2.5
General discussion area for the L32-chassis Altima
bwbarbour
Car: 2007 Nissan Altima 2.5
Where is the oil filter on the 2007 Altima 2.5? I crawled under the engine to find it and there is so much stuff there I could not see it. I hate paying big $ to have someone change oil when I have been doing this myself for 40 years!
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
now its been a while since ive worked on a 2.5 but it should be on the passenger side of the engine under a plastic cover, its hard to find initially but just look on the right side of the motor, its horizontally mounted
Scandinavian Flick
welcome to nico by the way, lots of useful people here
NissanAltimaGuy
Car: 2008 Nissan Altima Coupe SE 3.5
I can tell you where it is on the 3.5 which may not be relevant to yours:
[IMG][/IMG]
The arrows indicate 3 of the 5 plastic pieces that need to come off from the passenger side wheel well to remove the plastic shroud and get to it.
We need a 2.5 person to validate if the pic is even relevant.
ADKSaad1387
Car: 2012 Infiniti G37X
2007 Nissan Altima 2.5S Majestic Blue
i recently changed my oil myself just for fun even though i get them free at the dealer. but its kinda behind the brake rotors. its white if that helps haha and the opposite side of the end that screws in is facing outward toward the wheel.
Idok
Car: 2007 Altima 2.5 S/2008 2.5 coupe
It's on the passenger side. If you crank the steering wheel hard to the left you can actually see the filter up above and to the left of the suspension. The filter is horizontal and pointing out towards the wheel. It CAN be changed with out removing the wheel or the plastic liner between the wheel and the filter. I have been using a Napa Gold filter on mine.
Barchetta
Car: 2007 Nissan Altima 2.5S
Once I change the oil how do I reset the maintenance reminder on the dash?
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
Idok wrote:I have been using a Napa Gold filter on mine.
Sorry man but i wouldnt use anything from Napa. They sponsor Michael Waltrip. That dude stinks so bad. He is a disgrace to the waltrip legacy....
marlin29311
Car: 2008 Infiniti G35x
Actually the Napa gold filters are pretty darn good.
Get the silver one though - it's pretty much the exact same thing for cheaper
Return to “4th Generation Altima Sedan (2007-2012)”
