nuQ »
https://forums.nicoclub.com/nuq-u4532.html
Wed Dec 10, 2003 4:44 am
i have a local sts tire center that i take mine to. i go out and buy 6 quarts of mobil 1 0w-40, and a mobil 1 filter, then make an appointment for after work. i make sure the engine is hot when i pull it in and let it idle in the parking lot while i go inside to see what bay i should pull into. after pulling in, i usually just mill around the front of the bay keeping an eye on things. they follow all my orders, especially since i'm right there!!!
doing it this way, is a little more pricey (cost of oil, filter plus the change--usually around $13 to 15). this gives me piece of mind that it's being done right, any additives i want put in are definitly put in, and it all takes about 1/2 hour. well worth it. build a relation with a local shop, make an appointment then wait while it gets done so you can be sure it's done right. (never hurts to take care of the tech for extra special treatment on your ride, wink, wink!). remember, your car is your love and passion, to an oil change jockey, just more work. act accordingly. just my .2 cents! jeff
