changing my fuel filter shouild i change the pump too?
D_roc
Car: 2001 Maxima 20th aniv edition
car is 2001 max aim wiht 138k on it. i bought a filter so should i change the pump with it?, allso does the dealership sell the small screws that hold the top where the fuel filter is (under the back seat) coz i took it off one day and now some screws won't tighten maybe b/c the are rusted and fuel is leaking thanksD
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
If your fuel pressure is good and you have no corrosion on the pump terminals you should not need to replace the pump.
You may want to make sure that the fuel pump is sitting flush in the hole and replace the gasket around the pump on top of the tank. It is also common to strip the tank bolt holes. Look at all six and if you have small metal shavings in there then you will either need to repair it or replace the tank. Leaving even one of those bolts loose may(almost certainly) cause an EVAP code to set and gas to evaporate from the tank.
bpomps
u shouldnt need to change the pump unless its bad! ? i changed my filter on my 00'. getting the housing off was like a puzzle! my filter was dirty / oily / blackend and there was dirty/grime/metal in the housing - the tank was clear though from what i could see.
