Changing M37 tires for comfort ride ?
ameer
Car: 2011 M37
Hello ..
I have 2011 M37 .. my tires is 245/50R18
Can I go for 235/55R18 for a comfort ride ?
Is it fit and OK to go on ?
ameer
Car: 2011 M37
Hello ?
No one here ?
EniGmA1987
Car: '06 Infiniti M35 Sport
I think they would be less comfortable since the tires would be lower profile but wider. You would want taller tires for a bit softer ride, but your handling will suffer.
ameer
Car: 2011 M37
235/55 R18 is lower profile than 245/50R18 ?
what is your suggestions for taller tires ?
I don't care about handling that much, My speed less than 60mph ..
any suggestions are welcome ..
EniGmA1987
Your right Im sorry. I was remembering it opposite, I was thinking the first category was profile size when it is actually the second. So 235/55/R18 would be a little bit more comfortable. But since you are going for comfort you should also make sure and get some tires known for being very low noise and comfortable running, usually grand touring type tires. Something like these:
http://www.discounttiredirect.com/direc ... erformance
audtatious
One issue is while the 55 is a greater percentage of width it is a greater percentage of less width....the 235 will stretch out more on the rim as well.
To get taller tires you should look at 17" rims.
ameer
Car: 2011 M37
hello audtatious ,,
The new M has a big brakes so the 17 inch rims is not a good option I think ..
hello EniGmA1987 ,,
Thank you I think I will get one of these to try ...
audtatious
If you do have the Akebono's then you are absolutely correct in that 17 inch rims won't fit (may not fit with non-BBK either but I believe they would). Dropping down to 235 width with more height (55%) is not going to do much for the most part either as you are only talking + .3" sidewall difference. Now, changing to tires with less of a speed rating may result in a softer sidewall....something to look into at least.
