Postby
sothrowed »
https://forums.nicoclub.com/sothrowed-u20831.htmlFri Jan 07, 2005 12:55 pm
anybody has any information fo me, on how to change the brake pads for a 93 j 30 front and rear if so please post, a step by step with pictures would be great but anything would help
Postby
elwesso »
https://forums.nicoclub.com/elwesso-u5248.htmlFri Jan 07, 2005 1:33 pm
sothrowed wrote:anybody has any information fo me, on how to change the brake pads for a 93 j 30 front and rear if so please post, a step by step with pictures would be great but anything would help
If only the world would work like that.....
Sorry, welcome to the forum...
There are MANY threads about brake R/R... Search this forum.....
Postby
DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.htmlFri Jan 07, 2005 6:31 pm
Brakes aren't that bad really. You need to remove the wheel and then remove the caliper (2 bolts) The pads should just fall out. Not sure about the J, some Nissans require a special tool to get the pistons back in. If not, then you can just press them in simultaneously with a clamp and a block of wood.Definitely get your hands on a manual. It'll explain this with pics, plus you need the torque specifications for all the bolts when you're putting things back together.
