Clipsed »
https://forums.nicoclub.com/clipsed-u53627.html
Tue Jan 30, 2007 1:30 pm
Ok I decided to investigate this subject and found these results. I don't know about the instrument cluster yet, but seeing as how Jemdawg screwed his up, it might not be a good idea to investigate that just quite yet, so Jem if you have any pics of when you had yours disassembled, post them up here so I can see and compare. If not, can you verify if the LED's on the board looked like the ones below. Also I have figured out why only the lock on the lock/unlock button illuminates. See picture below.
Kind of blury, but the unlock side has the white part to swivel on it. The board has 6 surface mount LED's which if you have experience soldering those lil suckers is an easy replacement of a different color. I have been looking for a direct replacement LED but nobody seems to make one to the same specifications. At my work, we have some, but they only come in white, the color ones are a lil smaller, but more than likely would still work with a lil extra work. Although I could get the white ones and dye them to the desired color. I tried looking at the bulbs in the climate control, and those are regular fillament bulbs that you can pop out and replace, although I believe the orange color is a clear film on the panel itself as the bulbs are clear.
I will research this more, and possibly order the LED's to replace them. I am still curious and haven't looked at the other side yet, but think I can make all the window buttons light up.
