changing injct...
GZL-19T
whta is the bst way to change the inject.. what do u need to take off..
NeedCAforS13
Car: CA swapped S13 coupe
fuel rail, then they just come right out! the hardest part is those two bolts that hold the rail on! and make sure you get new rubber o-rings and seals that go on the injectors! otherwise, you'll get real good at pulling that rail;)
Sean
GZL-19T
i did that but it stiff did not want to come out.. there looks like there is another one under the end.. if u try and lift up to get out u prob could get 2 out but u would have to bend it to get the last 2 out....
datsunboy
Car: Datsuns
you need to un-attatch the fuel lines coming in and out of the rail too!
GZL-19T
ah k.. hmm and what then u just pull it up and slide them out...
it looks like there is 1 more screw under where the lines are coz that side wont lift up..
