Changing High Pressure P/S Line...Any Tips?
rico05
Car: 1992 RMS13 w/ CA18DET
Just checking if there are any tips anyone can give me? I assume that it will be an simple affiar, I was jsut checking for any input to make it easier. I pulled off my ProjectSilvia T/C rods cuz I don't want p/s fluid to make em look all nasty so I wanna hurry up and get this done so I can put em back on;)
NISTECH
no tricks. if it has brackets along its route holding it on remove these first so your not playing in p/s fluid trying to get them loose. then start by removing the end of the hose at the lowest point first with a catch pan under it. this way will drain the fluid down so it wont make such a big mess at the top where it connects to the pump. then remove the hose at the pump. Reinstall in the reverse order.
rico05
Cool. Exactly as I was going to do it. Thanks for the verification!
