slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Wed Apr 06, 2005 3:11 am
I'm sure someone here might be able to give you better advice, but to get you started:
I'd first set your crank to top-dead-center, just in case the lower chain slips off. I *think* the KA24E has a chain' holder/catch that engages if the chain is loosened, so when you unbolt that gear(you'll have to, no way arround it), the chain should stay relatively 'put. Don't quote me here, some fellow KA-E owners should confirm. Just in case, have someone keep tension on the chain, then use something to secure it while you ready the new gasket and head. Worst case you'll have to pull the lower cover to reset the chain/gear.
It's generally *not* recommended to use the chain/crank to back your wrench when unbolting the cam gear. They make a gear wrench(looks like a spanner wrench almost) that is used to hold the gear stationary while untightening. It's only there pretty tight, like 130-150ft-lbs, so you don't want to risk fudging your chain.
HTH, get yourself a factory service manual, it's all laid out there.
-Jamie
