changing fuel pump on 2002 nissan xterra
snoopie68
Car: 2002 nissan xterra
I have a question , do I need to drop the fuel tank to change the fuel pump, it has a acess hatch at the top of the tank and i have a book that says in one part to change it there and another part that says to drop the tank but the pictures it shows does not look like what i am seeing inside my tank. any help would be appricated, thanks Dan
snoopie68
can anyone tell me if i need to drop the fuel tank on my 2002 nissan xterra to change the fuel pump
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Pull up your seat cushion on the right side as well as the rear hatch area carpet. I haven't confirmed this (because my X is sitting at home) but there may be an access panel you can remove and not have to drop the tank.
Dropping the tank is a PITA and you have my sympathies if there's no acess panel to get at the pump.
