DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Mar 27, 2003 11:35 am
1) Remove blue 15amp fuel pump fuse from fuse array near the hood pull handle.2) Start the car and let it die. Then crank it several more times.3) Remove the front plastic trim cover right in front of the plenum...3 10mm fasteners.4) Cut off the short length of fuel hose right behind the trim and drain the fuel rail into a container. You may even want to blow the rail out with compressed air at 30psi, but it's not necessary. Obviously you'll need a length of fuel injection hose to replace the removed one. Take precautions against fire.5) Carefully remove the metal harness clip from the injector's harness connector.6) Pull the harness off the injector.7) Remove the 2 screws holding the injector cap down. Careful, they're on pretty good and easy to strip. Some techs replace them with hex-heads.8) Remove the metal spacer from under the cap.9) The old injector can be pried and/or pulled out. Make sure you remove both o-rings. If you drained the fuel rail properly, very little fuel should drain into the intake runner. Whatever fuel drains down will end up in the oil pan and thin out the oil. 10) Place the new o-rings on the new injector and place a bit of grease on them.11) Push the injector into the fuel rail, orienting it like the old one, and being careful to not pinch either of the o-rings.12) Replace the spacer, noting flat-side orientation, and fasten cap down.13) Place the clip on the connector first, and then place connector on the injector.14) Install new fuel injection hose and replace plastic trim.15) Install pump fuse.
Make sure the engine idle's smoothly and keep an eye on the exhaust for excessive white smoke. If you get a lot of fuel drain down into the intake, don't crank the engine till you're sure the gas is out of there, and change your oil soon.
