Changing Front Brakes S13 Hatch
rsxbadboy
I was able to change my rears with no problems...however for the fronts, how do you push the piston back? WIth the rears I just used the needle nose pliers and twisted it. How about the fronts? What did you use to push them back in?
Nick240sx
Car: 2009 Ford Fusion SE Sport
just get a vice grip and take the old brake pad turn it around put it between the vice grip and the piston and just tighten the vice grip, thats how i did it, itll turn right back
slimcat7m3
Car: s13
I do the same thing only I use a C-clamp.
rsxbadboy
thanks fir the help fellas...the c-clamp worked just fine
Nick240sx
im an idiot, i use a c-clamp too i was getting my tools mixed up. glad it helped!
