ghx407 »
https://forums.nicoclub.com/ghx407-u51111.html
Fri May 11, 2007 9:04 am
My car broke the ring lands on the #3 piston, so it gave me the perfect opportunity to overhaul the engine. The previous setup was a GT28R with 370s, stock MAF, and stock bottom end. It put out 234HP, was very reliable, and tons of fun.
Since the motor has 172k miles on it, it was the perfect opportunity to overhaul almost everything. Here's my new setup; it should be up and running in 2-3 weeks:
Walbro 255 pumpDW 740cc injectorsNismo FPRZ32 MAFEFI Specialist ECUApex'i SAFC for fine tuningCometic HGArias 8.8 pistonsEagle ESP rodsCalico bearingsNissan oil pump (new)Nissan timing chain kit (new)SS headerTial 38mm WG (10.15 psi/0.7 bar)HKS SSQ BOVEbay FMICFlex-a-lite dual fansACT clutch kitAnd I'm topping it all off with a Chinese knock-off T3/T04E (63 hot, 50 cold, 57 trim) turbo!!!
I'm keeping the current water pump because it has less than a year on it. I also have a Garrett GT35 (63 hot, 70 cold, ?? trim) which needs a rebuild, but I want to see how long the $200 turbo lasts. Feel free to make bets...
