tutor772 »
https://forums.nicoclub.com/tutor772-u240296.html
Wed May 20, 2015 8:59 pm
I struggled with this, too. But I was able to change the filter last weekend, and with the help of the factory service manual section, it turned out not to be too difficult. (The explanation in the Owner's Manual was no help to me.)
Download the "EM" section of the FSM from the link in the previous post. Go to page 24 of the EM section. The item you need to remove is item 12 in the diagram--"Air cleaner case duct". As you stand at the front of the car looking into the engine compartment, the case duct runs from the "air cleaner case (lower)" (item 3 in the diagram) around the right side of the battery. The case duct slides up and down the air cleaner case. There is a small "clip" at the top of the air cleaner case that holds the duct to the case. Gently lift up on the clip, and gently pull the duct forward and up slightly, releasing it from the case. At the other end of the duct, next to the battery, there are 2 more clips on both sides of the duct. Pinch the clips to release them (or pull them out from their bottoms, whichever works for you). Once the 3 clips on the duct are released, lift the duct straight up out of the air cleaner case. The sides of the duct have grooves that engage the corresponding grooves in the air cleaner case. Then release the 2 clips holding the air cleaner case together, pull the case apart, and lift the filter out. Pay attention to how the filter fits in the case. The filter gasket is angled, and the new filter has to be put in correctly in order to be able to close the case. If you put the new filter in "upside-down" it will look like it fits, but you won't be able to clip the air cleaner case back together.
BTW, I bought a non-OEM filter on eBay for around $10. Wrong. The filter I received was for a 2014 Rogue Select, which isn't the same car or filter as the 2nd generation Rogue. I ended up buying an OEM Nissan filter for around $30 and (surprise!) it fit perfectly.
