Changing drivers side headlight bulp
jroo
Car: 2004 Nissan Pathfinder
Last night in traffic my drivers side headlight went out. I grabbed a set of bulbs from Pep Boys and started to change the bulp in the parking lot. I couldnt fit my hand behind the headlight case and the airbox at all. My finder could barely touch the plug wire hanging out the back. I assume that I have to pull the whole headlight out to get to the back or am I missing something?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Page 8-28 of the owner's manual shows instructions. I don't believe you should need to remove anything in order to change the bulb. I can't quite remember if I encountered difficulty with either side last time I changed headlight bulbs, so if my reply is useless I offer my apologies in advance.
yngw13
Car: 2001 Nissan Pathfinder SE
OP has big hands...I think that is the case...
the driver side seems to be the harder side to replace...
I think removing the airbox and/or battery could benefit for more working room///space...
once you remember that there is a rubber cap and then clips you need to unlock its ez pz
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
The driver's side is the more difficult of the two because of the airbox, but it's possible to change it without taking out anything. You'll need a stubby or angled screwdriver and some great dexterity with your fingers, though.
The first couple times I did it, I got frustrated, disconnected the air intake and took out the airbox. After that I finally got used to it.
