Postby
Kar »
https://forums.nicoclub.com/kar-u213491.htmlFri Jan 11, 2013 3:21 pm
Hi all,
I`m going to change my drive belts, 2 idler pulleys and air condition pulley.
Is it hard to do it and if you have any advices to share will be much appreciated.
Postby
Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.htmlSat Jan 12, 2013 10:08 am
The drive belts aren't hard. There's a tensioner screw to back off on, and then they come right
off. You do need to tighten the tensioner pretty good (more than you would think), or you'll have
belt squeal on start-up.
Why do you think you need to replace the pulleys? My '01 is at 221,000 miles and the pulleys are
fine.
Postby
Kar »
https://forums.nicoclub.com/kar-u213491.htmlSat Jan 12, 2013 11:21 am
Well,
Mine is on 73k miles and belts definitely need to be changed for the pulleys they seems good but I just want to change them to avoid future problems.
