Changing differential oil on '05 G35 sedan MT
fountainpenracing
There is great info on changing the MT transmission gear oil that Joe posted. However, does anyone have any info on changing the differential oil? Change is called for at 30k miles.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
G35- How to Change your Differential Gear Oil-
Items Needed
1.4L API GL-5 SAE 80W-90 (Rear Final Drive).65L API GL-5 SAE 80W-90 (Front Final Drive-AWD ONLY)New fill AND drain plug gaskets
DIFFERENTIAL GEAR OIL Changing Differential Gear Oil
DRAINING1. Stop engine.2. Remove drain plug and drain gear oil.3. Set a gasket on drain plug and install it to final drive assemblyand tighten to the specified torque (34.5 N m or 25 ft lbs)
CAUTION:Do not reuse gasket.
FILLING1. Remove filler plug. Fill with new gear oil until oil level reachesthe specified level near filler plug mounting hole.2. After refilling oil, check oil level. Set a gasket to filler plug, theninstall it to final drive assembly (34.5 N m or 25 ft lbs).
NOTE: The drain plug is the lower bolt (seems to face towards the rear of the vehicle) and the fill plug is the higher bolt (seems to face the towards the passenger side of vehicle).
To Check the oil level. Place your finger in the filler hole (WITH THE ENGINE OFF). The level should be level with the filler plug hole.
SAE 90 is suitable for warmer climates with ambient temperatures above 32 degrees F (0 degrees C).
fountainpenracing
Great stuff - thanks much.
