Adjusting the damping didn't help. I tried many different adjustments, they only made the ride worse. I ordered some swift springs. I'll post a review when I get them on.Darius wrote:If your car is bouncing after you hit a bump/dip, that means it is underdamped and you need to set the shock setting to a harder level. It doesn't have anything to do with the spring unless your shocks can't dampen it because it is too stiff.
