jlaudio_21 wrote:About to do this myself, except in my s13... Upon taking the bolts out of the trans mount it will lower the end of trans side. I believe this will allow enough room to reach the undesired bolt at the top. If still not enough room front subframe can be unbolted and lower the whole engine and everything just enough to allow room for the swap. Just lowering it could result in not having to unbolt/unhook anything as far as engine components. Just to check this just unbolt the trans mount and lower it to check all clearances and if bolt is reachable.
Hope this helps.
-Brian C.
