They are extremely easy to change. All you need is (I think) a 12mm for the tension pulleys. Loosen those up, pull off the old belts and slide the new ones on. Nothin' to it.OptimusPrime wrote:While getting my oil change today (M1SYN) they pointed out that my serpentine belt and the fan belt were cracking. Are these 2 belts easy to change without alot of tools? What I have is a medium size socket set (standard and metric) and a variety of wrenches. If not then I gues I can pay to have it done.
if it's too tight or loose would it cause the belt to squeal?DAEDALUS wrote:The pulley nuts have to be loosened before adjusting the tensioners. Otherwise you'll destroy the tensioner rod threads.
I have the same problem. BTW all of my belts was replaced a few months ago.gniknave wrote:I get a squeal on a morning (first) startup. Think that could be loose belts?
