Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Thu Mar 20, 2003 11:40 am
Changing belts is easy ... what you need is a socket set and something to turn them with.
First off remove the clutch fan... its 4 10mm bolts I believe. On the bottom of the fan shroud you can remove a part of the shroud to pull the fan out of.
There are tensioner bolts that you can locate in the car, aka I dont know where they are at the moment. Each belt has one if I remember right. Now what you do is loosen those tensioner bolts and the belts come right off. Then you put the new ones on and retension them. Dont tension them too tight else the belts will break. Too loose and they will squeal.
Its not hard at all. Then you just put your car back together and drive off.
