Noel J »
https://forums.nicoclub.com/noel-j-u153225.html
Fri Mar 12, 2010 3:08 am
I did them myself (first time changing belts) and it only took me about 20 minutes.
First lift the car and place on jacks.
Remove the top 3 covers, and the one underneath the car.
Use a 14mm socket to loosen (do not remove) the first tensioner (power steering, alternator, and oil pump belt), and then the second tensioner (A/C compressor belt). There is a diagram below that illustrates all of this.
Go underneath the car and loosen (only enough to get the belt off) the bottom bolts for each of the tensioners with a 12 mm socket. Again see diagram below.
Remove the old belts, and replace with the new belts in reverse order. Remember, smooth pulleys make contact with the smooth side of the belt and vice versa. BE SURE ALL THE BELTS ARE SEATED PROPERLY BEFORE MOVING FORWARD.
Go back underneath the car and tighten the bottom tensioner bolts. BE CAREFUL NOT TO OVER-TIGHTEN THE TENSIONERS AS THIS WILL OVER-TIGHTEN THE BELTS. YOU MAY WEAR OUT BEARINGS BY DOING SO. A good rule of thumb is to be able to push the belt about 0.5 inch with about 5 pounds of force. This is usually reasonable and would fall into proper specifications.
Use a little grease (I used WD-40) to spray onto the top tensioner bolts. BE SURE NOT TO GET ANY GREASE, OR OTHER FLUIDS, ON THE NEW BELTS.
Tighten the top tensioner bolts to 28 ft/lbs.
Double check the tension, diagram, and that all belts are seated properly.
P.S. I recommend Good Year Gatorback belts from AutoZone. They seemed to be of better quality than the dealer's belts and are much quieter. They're about $40 for both.
Modified by Noel J at 10:59 AM 3/12/2010
